Testing for Vac leaks on intake system
Guardian
What model do you have?: '77 1600 S
Re: Testing for Vac leaks on intake system
Post by Guardian »
John Alves wrote:
Tony Z wrote: you could prob use deodorant if you wanted, .
Doom also works, but that kills bugs dead
Whahahahaaaaa!!! :lol:
Eugene Pfeil
What model do you have?: 68 beetle
Post by Eugene Pfeil »
Is there an easy quick way on how to repair that leaks
Been thanked: 487 times
the quickest easiest way is to fix it properly. Otherwise you will be patching your patches for years.
Its cheaper and quicker to do it right once than to do it wrong twice
Eugene Pfeil
Can that leaks have caused damage
leaks make the engine run lean.
Running lean will eventually destroy the engine - sometimes slowly, sometimes in seconds...
Eugene Pfeil
Because I think one of the bolts is stripped where the intake manifold goes into the head. Would this cause a vacuum leak or not??
yes it would
Eugene Pfeil
Must I take the engine out to repair that, or can I repair it, while it is in the car
that you will have to decide for yourself. I would pull the engine out
Eugene Pfeil
Would it be easy to take the engine out, and how long wil it take me
start a new thread, this topic has gone from vac leaks to removing the engine
scrappy
What model do you have?: 1974 beach buggy
Has thanked: 2 times
Post by scrappy »
Thanks for the advise- experience often solves a problem faster than fiddling about and wasting time
colignym
What model do you have?: Beach buggy
Post by colignym »
For air leak check, try this:
Take of taperd covers.
Turn engine until valves are closed (cams rocking )
Take of carb
Place air pressure nozzle from compressor at inlet manifold, and blow air in, (sealing between nozzle and manifold with cloth or prestik) you will hear exactly where it is leaking. If there is no leaks, it will keep the pressure, and blow back when you release.
No guessing, works perfectly.
swiggs
What model do you have?: 1969 Beetle 1641cc
Post by swiggs »
Hi, can a vacuum leak cause a acceleration stumble/hesitation at low rpm, say 1800 - 2000rpm?
it is possible, but you have a centermount dellorto carb, so its probably jetting issues.
