1962 T1 resto cal project
- What model do you have?: 62
- Has thanked: 8 times
- Been thanked: 14 times
Re: 1962 T1 resto cal project
With my car still at the paint shop and crankcase at Bruce's place i was getting a little frustrated about not being able to do anything so i decided to refurbish my speedometer so long, nice little project.![Image](//images.tapatalk-cdn.com/15/09/04/886a9ca5dacf3a80c7d7ba77c9ce3f8e.jpg)
![Image](//images.tapatalk-cdn.com/15/09/04/98bf36f6e861db5c0b2b9c7f6ed6268b.jpg)
![Image](//images.tapatalk-cdn.com/15/09/04/7d42d5f549d6674ef992f55ab6d10675.jpg)
It wasn't looking toi bad but when i tried to turn it with a piece of the old speedo cable it wouldn't budge. Tried all kinds of penetrating fluid and i didn't want to force it but no luck. I'll have ti open it up.
![Image](http://images.tapatalk-cdn.com/15/09/04/886a9ca5dacf3a80c7d7ba77c9ce3f8e.jpg)
![Image](http://images.tapatalk-cdn.com/15/09/04/98bf36f6e861db5c0b2b9c7f6ed6268b.jpg)
![Image](http://images.tapatalk-cdn.com/15/09/04/7d42d5f549d6674ef992f55ab6d10675.jpg)
I opened it up cleaned and polished the stainless steel bezel and surpirising enough the rubber seals were in perfect condition and not perished at all![Image](//images.tapatalk-cdn.com/15/09/04/6b9cfe60ea796363f3cffea7d880bf69.jpg)
Since this will be a total restoration and new motor i went ahead and rolled back the odometer![Image](//images.tapatalk-cdn.com/15/09/04/25c5fc15f8ed085d030aa52e9b992f31.jpg)
When i opened the magnetic cup i found the old grease was rock hard and that's why it wouldn't turn over.![Image](//images.tapatalk-cdn.com/15/09/04/40325c24622ad2d1ce62e94246434f24.jpg)
![Image](//images.tapatalk-cdn.com/15/09/04/8aef5c61d3452706145ed370d45ba722.jpg)
With everything cleaned up i replaced the indicatir and warning light gels and cleaned ip the case a little, it was a bit tricky to get the little needle back into its brass bushing but she came out nice.![Image](//images.tapatalk-cdn.com/15/09/04/6c2aee1ea588c81c122e1cd512fa8628.jpg)
![Image](//images.tapatalk-cdn.com/15/09/04/b7fb94d1b2e8667de44cafb33540e61f.jpg)
![Image](//images.tapatalk-cdn.com/15/09/04/f21585877f42992e387e36b43395b3f3.jpg)
![Image](//images.tapatalk-cdn.com/15/09/04/3440e4078fd6985c26debbe64b8447a7.jpg)
![Image](http://images.tapatalk-cdn.com/15/09/04/6b9cfe60ea796363f3cffea7d880bf69.jpg)
![Image](http://images.tapatalk-cdn.com/15/09/04/25c5fc15f8ed085d030aa52e9b992f31.jpg)
![Image](http://images.tapatalk-cdn.com/15/09/04/40325c24622ad2d1ce62e94246434f24.jpg)
![Image](http://images.tapatalk-cdn.com/15/09/04/8aef5c61d3452706145ed370d45ba722.jpg)
![Image](http://images.tapatalk-cdn.com/15/09/04/6c2aee1ea588c81c122e1cd512fa8628.jpg)
![Image](http://images.tapatalk-cdn.com/15/09/04/b7fb94d1b2e8667de44cafb33540e61f.jpg)
![Image](http://images.tapatalk-cdn.com/15/09/04/f21585877f42992e387e36b43395b3f3.jpg)
![Image](http://images.tapatalk-cdn.com/15/09/04/3440e4078fd6985c26debbe64b8447a7.jpg)
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
looks brand new !!!
- riaanj
- Has thanked: 6 times
- Been thanked: 41 times
Came out awesome, looks brand new!
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
Okay so I'll post a few pics. I started off by building some wooden beams that i can rest the shell on, allowing me to get good access to the pan and front suspension without wasting too much space.![Image](//images.tapatalk-cdn.com/16/01/25/de5a5c2fb3761fd6d5d521ca15fae7e2.jpg)
![Image](http://images.tapatalk-cdn.com/16/01/25/de5a5c2fb3761fd6d5d521ca15fae7e2.jpg)
The original tank looked like a siv, managed to find one right here on ACVWSA, not 100%, had some dings and dents but all importantly, no rust. Stripped old paint and had a friend braze on a fuel return bung. It then got dipped in Chemloch rust remover and i finished the inside if the tank with an epoxy based tank sealer i got from Henry Kinnear, same stuff they used to seal inside of aircraft wet tanks. Then came a nice shiny gloss black.![Image](//images.tapatalk-cdn.com/16/01/25/385a4c0896954da84594d6481b0804e2.jpg)
![Image](//images.tapatalk-cdn.com/16/01/25/d76a0fc3ffba602b8cdeb22a426a88c5.jpg)
![Image](//images.tapatalk-cdn.com/16/01/25/1c77035eb46f59e32426eddc4dfbb0a4.jpg)
![Image](//images.tapatalk-cdn.com/16/01/25/71324f40c77416066f23bd85e6fb4475.jpg)
![Image](http://images.tapatalk-cdn.com/16/01/25/385a4c0896954da84594d6481b0804e2.jpg)
![Image](http://images.tapatalk-cdn.com/16/01/25/d76a0fc3ffba602b8cdeb22a426a88c5.jpg)
![Image](http://images.tapatalk-cdn.com/16/01/25/1c77035eb46f59e32426eddc4dfbb0a4.jpg)
![Image](http://images.tapatalk-cdn.com/16/01/25/71324f40c77416066f23bd85e6fb4475.jpg)
