Autovilla motor conversion
HippyPete
- What model do you have?: Kombi
- Has thanked: 4 times
Hi guys, am a newbie here, hoping to get some advice. I'm looking at fitting a 2L golf motor in an autovilla, here's a few questions I have;
1) what is the prefered motor to use, 8v/16v, which series (2/3/4), efi/carb?
2) should I can the std auto box? If so, what is a good replacement, and who could make the adaptor plate?
3) what would be a good radiator to use, and in what position? ( have a lot of pattern making and fibreglass experience, so building stuff is not a prob.)
4) what disc brake conversions are locally available?
Looking at doing as much of the work myself.
Thanks, looking forward to hearing from you guys.
- Been thanked: 541 times
Re: Autovilla motor conversion
How about posting photo's of your bus, and why you want to fit a water cooled motor, give more info, and we will be glade to share info with you,
We will all be speaking the same thing then.
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Why do you want to fit a motor from a Golf?
Autovillas also already have disk brakes, why do you ask?
HippyPete
Will be picking it up next we, bought it as a project, and thus not running. ( motor in pieces).
I' m planning on travelling a bit with it and would like it to be able to tow a trailer with 2 road bikes, so need a little more power than std, don't really want to go the whole V6 route.
Already has disc brakes? Great, never knew.
Appreciate the feedback, thanks guys.
- slak
- Has thanked: 7 times
- Been thanked: 32 times
Hi welcome to
ACVWSA and owning a vw
U should get in contact with Pierre from Vdubtech they do a lot
of Golf conversions but also do very nice Aircooled rebuilds and he is Great with
Gearboxes and Advice
Vdubtech 011 822 2799
U Only Live Once Right !!!
- sean
I would never even consider towing anything with a Golf, so putting an engine like that into a much bigger car is going to be even more underpowered. You will be disappointed with a Golf motor in there. If you want towing power, what about a Lexus V8 if you are quite sure you want to hack it for a watercooled conversion?
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
I am a big fan of the 2.0 8v Golf conversions , running a injected setup with mp9 is super reliable , engine power is more than enough for towing but gear ratios might be a issue. There is allot of info online reg this . Since you don't have a location listed its a little hard to refer you to someone in your area .
HippyPete
Here's some pics guys. Am going up to Joburg tomorrow, and will drop by Pierre at Dubtech, and see what the way forward is getting a good motor and gearbox in there. Anybody got an idea where I can find new/good lights and lenses from?
- Derek
- What model do you have?: 1971, 1972, 1978
- Facebook: Derek Antonio Serra
- Been thanked: 25 times
I hope you don't need rear lights and lenses mate - I'm pretty sure they are nearly impossible to find for an Autovilla. Front lights and lenses from Volkspares...
'70 Dormobile - 1.6
'76 Brasilia - 1.6
'76 Brasilia - 1.6
Terry Phillips
- Has thanked: 193 times
- Been thanked: 121 times
Google Gilo engineering and look at all the conversions you might get some answers there. Just remember lots of the engines are now out dated and a camper fully loaded with a trailer with bikes you are going to need to make the right choice first time round so do your homewok first.
HippyPete
Derek, unfortunately the rear lenses are in terrible co nd, although not broken, they faded and cracked up. Will make a silicone mold, and cast a new set in casting resin.
kingpeanut
- What model do you have?: autovilla
- andyrtmorgan
- What model do you have?: '59 Ghia Coupe
Hi guys, any final decision on the best engine to fit to an Autovilla? Quite tempted to get hold of one and do it up as a holiday vehicle just don't want to use up all my leave getting to my destination!
'59 Ghia
