to those using Aluminum cases
Hey guys, this goes out to anyone putting together a new engine with the new aly blocks.... Rui, Bugger......
Dont make the f-up I did. Looking back, I should have seen it, but it didnt even cross my mind. I got the engine out today to see what it stopped with a bang and eventually found the problem. Fan belt pulley. The same one I used for years on my various 1600cc versions.
DO NOT, I repeat, DO NOT use an aluminum pulley with an aluminum case. I will prob pick up and seize the engine. Scrapping the pulley and possibly the block.
I was lucky, mine isnt too bad, but the pulley is throw away material. Still needs a full teardown and a touch up on the case.
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
Those things shouldnt touch each other ever as there is quite a large clearance between pully and case std they never touch.
A
I had the same problem last week with a pulley I bought from Goldwagen.The problem is,the packaging says "oversize",and that is where the problem lies.
If it is standard,Ally or steel,it should not be a problem.Mine was steel,and after the third turn it was so tight,I thought the motor siezed.
vader
Post by vader »
Bummer Dude!!
my pulley was not oversized and has run about 40 000 km in the mag case. I know there is clearance, but it still picked up something. Actually have done some research, its not the first time its happened. Time to do some more research to come up with some results.
4agedub
Been thanked: 13 times
Post by 4agedub »
I'm running a ally pulley with my empi casing. No problems at all.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
Hy Tony let us know when you figuered out what want wrong
May be some shaving or something small got in there and started thewhole shit
4agedub
Post by 4agedub »
I see on the shoptalk forums there are other guys complaining about the same thing, but I have not had any problems.
I have now found a few problems, but will not write until I know for sure what went wrong. Waiting for a few emails to be returned.
do yourselves a favour and read this topic....
http://www.shoptalkforums.com/viewtopic.php?t=108498
Type4s don't have all these problems :P :twisted:
But they do drop valve seats :wtf:
yes yes yes, its a bit late to build a T4 now....
vader
Post by vader »
So when are you putting it back together???/
busy trying to organise a few bits... then it all depends on the time I have between studies. Maybe Nov and then I go back to sea in Dec.... how ironic
Are yoou making it Sea worthy :?: :shock:
