My Beetle, Beebo
Riaan.N
Oil Seal
Has thanked: 3 times
Been thanked: 38 times
Re: My Beetle, Beebo
Post by Riaan.N »
73type2 wrote: Tue Oct 30, 2018 2:47 pm You might be overthinking this. Nothing could go wrong if you unscrew the top. You'll find a sieve and gasket as in your pic above. Take them out and clean them, as well as the pump bowl. The pump looks very new so I doubt whether you need to buy any new parts.
Yeah, maybe I am overthinking it... :-)
Riaan.N
Oil Seal
Post by Riaan.N »
sean wrote: Tue Oct 30, 2018 8:47 pm That is a stock standard late beetle fuel pump (the one for alternator system).
Thanks Sean.
sean wrote: Tue Oct 30, 2018 8:47 pm Leave it just as is. Don’t scratch with it, just add the inline filter.
I can't promise anything... will have to see how itchy my fingers are when I replace all the rubber fuel line bits :D
Riaan.N
Oil Seal
Post by Riaan.N »
The braking system has been redone... new slave cylinders, new brake pads, new rubber hoses. On two of the old slave cylinders, one of the pistons were stuck. Would still like to replace the single circuit master brake cylinder with a dual circuit one and also replace the piping from the reservoir.
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
Good going Riaan. I'm also thinking of installing dual circuit master cylinders in my Beetles, so please let me know when you find a source
Riaan.N
Oil Seal
Post by Riaan.N »
73type2 wrote:Good going Riaan. I'm also thinking of installing dual circuit master cylinders in my Beetles, so please let me know when you find a source
I’ve been told that the master brake cylinder of a Mk1 Golf 17mm IIRC will work using a spacer. I think there is also some info about it on this forum from some member(s) having done it.
Will post about it when I get thereImage
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
I posted that pic before of the golf mc with the spacer but it is only usable when youve got disc brakes aswell. Something to do with a residual valve inside the master cylinder
Riaan.N
Oil Seal
Post by Riaan.N »
buggyfan wrote: Mon Nov 19, 2018 5:31 pm I posted that pic before of the golf mc with the spacer but it is only usable when youve got disc brakes aswell. Something to do with a residual valve inside the master cylinder
Thanks Buggyfan :) Will do some reading up.
buggyfan
Long Block
Post by buggyfan »
73type2
France
Post by 73type2 »
So what options are there if you're not going to use disc brakes?
Been thanked: 487 times
residual pressure valves
73type2
France
Post by 73type2 »
Thanks. I googled it and it seems like a simple enough concept. Can these be obtained from the general parts places in South Africa?
that I cant tell you.
I've bought from Willwood in the past, but they are imperial threads and the locals dont have anything that will adapt...
CB performance in USA also has but I havent bought those from them yet.
Riaan.N
Oil Seal
Post by Riaan.N »
73type2
France
Post by 73type2 »
Thanks Riaan. I will keep that in mind.
Riaan.N
Oil Seal
Post by Riaan.N »
73type2 wrote:Thanks Riaan. I will keep that in mind.
No problem, had to look for myself as wellImage I’m pretty sure that there should be other suppliers also.
