Do beetle seats fit a variant 412?
mhsmuts
What model do you have?: Variant type 4, 412
Been thanked: 4 times
Post by mhsmuts »
Hi there, do beetle seats fit a variant 412? I'm looking at replacing my seats and would like to do it as a set.
Sent from my SM-G950F using Tapatalk
Camshaft
Been thanked: 107 times
Re: Do beetle seats fit a variant 412?
Post by Haans »
Not to my opinion,......beetle seat rails I believe is narrower,....me thinks
Been thanked: 539 times
your type 4 seats should be more comfortable then Beetle seats, from my experience.
Just have them re-upholstered with extra foam
OMO
Camshaft
Post by Haans »
Would it fit the rails ?
Haans wrote: Tue Dec 04, 2018 10:04 am Would it fit the rails ?
would not know, as as far as I know the 412 seats are wider, so the rails would be too.
Me Thinks..
mhsmuts
Post by mhsmuts »
My front seats are non standard and although in great condition do not fit the look I am working on. Variant seats are difficult to find..
well in that case, you can take the rails off the existing seats and fit them onto the new beetle seats.
You may have to bend the leg tubes to the right width or weld a flat bar to the bottom 1st,
Camshaft
Post by Haans »
What I do know is that a ghia pan and beetle pan is not the same,...ghia is apparently the same as Type 3 pan.
I measured ONLY after I off loaded a beetle pan at home !!!🙄....lesson was short but expensive !. The ghia that required this pan has since been moved on !
Thanks boet
mhsmuts
Post by mhsmuts »
Thanks guys
