Good. Are you using the Dicktator FI as originally planned, did the programming turn out well? Which cam profile did you end up with? Could van der Linde do the Web-73? Compression ratio?
In the end I did not go the FI route,I got a good set of carbs for a good price and fitted that.To be honest I can't remember the cam profile that I used but was close to a mild engle cam grind(I got the specs from IMPI) and it has a compresion ratio of 8:1.I am very happy with the power delivery,its a nice nippy/torqy engine in my opinion.
