'72 Deluxe bus
Kaptein
Has thanked: 2 times
'72 Deluxe bus
Post by Kaptein »
Hi everyone
I wanted to start this thread for my baywindow that I bought recently . I'm not to clued up with the busses but I've owned a couple of aircooleds before and thought its time for a bus.
Its a original, unpainted, unmolested rustfree lowlight baywindow
First of some pics
(These are the pics the PO took for the ad he posted)
And this is when I fetched it on Saturday
So there is 1major issue with the bus..
-I bought the bus without a engine...
What I've done so far is sourcing a engine and some missing or broken parts
I got a engine from Hendrik which I'll be fetching on Saturday
Bought some mirrors today
And fitted them
So I'm looking for some parts..if anyone has or know where I can get
Deluxe trimming/moulding clips
Deluxe bumper rubbers
Middle seat chrome ashtray
Thanks for looking
Ferdinand
sean
Has thanked: 63 times
Been thanked: 227 times
Re: My '72 Baywindow Delux
Post by sean »
That's a very nice colour. Not often you see them in that green. With some nice polishing, that paint will be rejuvenated quite nicely. :hangloose:
What type motor have your purchased?
Kaptein
Post by Kaptein »
Thanks Sean
I've started with the polishing and is coming out nicely...
I found a 2.0 Feul injection type4 engin, and its not realy the right engine for the bus as it originally had a 1700 carburettor engine but I think the bigger capacity will aid in the much needed oomph department
And with the FI, tuning and fuel consumption would be better
I will be rebuilding the engine before it goes in
Congrats again Ferdinand, what a beauty.
I might have an ashtray for you. Will have to hunt around though.
Kaptein
Re: My '72 Baywindow Deluxe
Post by Kaptein »
Thanks Paul, I would appreciate it
Derek
What model do you have?: 1971, 1972, 1978
Facebook: Derek Antonio Serra
Been thanked: 25 times
Post by Derek »
Very nice bus which looks like it is in amazing condition - great find!
'70 Dormobile - 1.6
'76 Brasilia - 1.6
Stütz
Been thanked: 19 times
Post by Stütz »
Awesome, awesome find. That's very high on my list of nexts too. Lovely.
3104
sean
Post by sean »
Kaptein wrote:Thanks Sean
Type 4 is the nicer motor to have in the baywindow's, the type 1 is pretty pap in the bigger bus.
2.0 Type 4's never had the Bosch D-Jetronic here, only 1700's. Are you sure its a 2000? That fuel injection system wont work properly if its fitted to a 2000L.
Kaptein
Post by Kaptein »
I am not 100% sure..I will make sure on Saturday when I fetch the engine..I just did a google search and saw the 2.0 had fi, but if its a 1700 its also good, 1 little step closer to be original
Kaptein
Post by Kaptein »
Thanks for the comments everyone!
Regarding the paint..I've started polishing it 1 panel at a time
I start off with Shield SP3 compounding paste to remove the oxidation
Then I use Wynn's revive -its a milder oxidation remover-but I use this mostly to remove the swirl marks created by the buffing mashine-I do this by hand
And then finally I use Wynn's Detail to seal the paint and give it a nice shine
Also by hand
Kaptein
Post by Kaptein »
Ok so today I got some parts that was needed
First off the black padding behind the drivers seat was broken
Got a almost perfect one
Wil fit it later, together with the steering wheel and pedal rubbers and gearlever boot that I got
Also I got the engine which we confirmed is a 2.0 starting with engine no CU.I got it with all the fuel injection stuff like the harnass, airflow meter, feul pump etc. But noticed that this was a aftermarket fitment into that bus it wasnt a original fi bay
My plans for now is to disassemble the engine for rebuild.I am a qualified mechanic so have more or less a idea of how to go about these aircooled engines and I read up alot about them all the do's and don'ts. But I would appreciate if the guys that really know these engines give me some input on what to do and what to look out for..
I also plan on ditching the Digitronic system and fit a Dictator management just to keep the engine bay neat and so I can fine tune the engine on a dyno.
Here's the engin that I bought
I got a qoute from volkspares for a Mahle pistons and barrel set-R5500 , if anyone knows where I can get it at a better price please let me know.
My bus also came with 3 stock wheels an 1 merc wheel, so I got 2 stock wheels from Hendrik. Now I have a full set
Ferdinand
Kaptein
Post by Kaptein »
UPDATE
So I've disassembled the engine I bought...turns out to be a no go.
But I will be using all the tin, Fi system etc of this engine.
I've considered fitting a 2.0 import motor, which I did not really wanted to do but after a day or two of thinking it over I've decided to keep it aircooled.
I got a 1700 case with crank and rods from Aramand .He has offered to help me build a proper reliable 1700 type 4 engine.So as of today I'm just gathering parts for the build. I got the pistons, rings and gasket set today.Ordered the bearings, oil pump and exhaust from Rui
I've also removed the bumpers and will be taking them for sandblasting tomorrow. Then I'll etch prime and repaint them l87 silver white(mix a color close as possible) .
Otherwise im just busy cleaning everthing
Ferdinand
This really is great news re keeping it 1700 and having Armand's input and help there :hangloose:
bugspray
Floorpan
Has thanked: 24 times
Been thanked: 16 times
Post by bugspray »
Ah. Man. You're the dude that beat me to it!super pissed at you bud. Haha. I was just not in town that weekend.
Offered to pay anyway but my messages didn't get to him.
Contracts on the purchase. Hope you make sure it stays in SA and is well looked after
Kaptein
Post by Kaptein »
Thanks, I will definitely keeping it in SA.And will be holding onto it for as long as I can
I must just get it running for now, but getting hold of 1700 cylinder heads is becoming a major hassle.
