Golf4 gti misfires
lotteringjoshua3
What model do you have?: golf4 gti 2001
Golf4 gti misfires
Post by lotteringjoshua3 »
Hi I own a golf4 gti bought the car recently by a guy but I did not drive the car away from there coz of a missing key I towed it away after laser cutting new key I heard the car had a misfire checked camshaft sensor checked air flow spark plugs module ignition coil everything is 100% spark plugs burning white but still have a misfire when I pull in a second gear dies out under my foot what could be the problem really need the help
Sent from my SM-J400F using Tapatalk
V6 Capri
What model do you have?: 1972
Has thanked: 7 times
Been thanked: 29 times
Re: Golf4 gti misfires
Post by V6 Capri »
1964 Ford Anglia 997cc
1972 Ford Capri 3L GT
1996 Escort 2L Zetec
2016 VW Touran 1.6TDi
1971 Baywindow project
V6 Capri
Post by V6 Capri »
Sounds like it happens when under load?
Plugs burning white is either it running lean, or too hot.
Check the injectors and fuel pressure maybe?
Could be timing is out and the injectors or spark plugs fire at the incorrect time too?
lotteringjoshua3
V6 Capri wrote:Sounds like it happens when under load?
Thanks will check that out it does have a small back fire could be timing
