Hi I own a golf4 gti bought the car recently by a guy but I did not drive the car away from there coz of a missing key I towed it away after laser cutting new key I heard the car had a misfire checked camshaft sensor checked air flow spark plugs module ignition coil everything is 100% spark plugs burning white but still have a misfire when I pull in a second gear dies out under my foot what could be the problem really need the help
Sent from my SM-J400F using Tapatalk
Golf4 gti misfires
- What model do you have?: golf4 gti 2001
- V6 Capri
- Has thanked: 7 times
- Been thanked: 29 times
Re: Golf4 gti misfires
1964 Ford Anglia 997cc
1972 Ford Capri 3L GT
1996 Escort 2L Zetec
2016 VW Touran 1.6TDi
1971 Baywindow project
- V6 Capri
Sounds like it happens when under load?
Plugs burning white is either it running lean, or too hot.
Check the injectors and fuel pressure maybe?
Could be timing is out and the injectors or spark plugs fire at the incorrect time too?
Thanks will check that out it does have a small back fire could be timingV6 Capri wrote:Sounds like it happens when under load?
