- 4agedub
- Has thanked: 4 times
- Been thanked: 13 times
Ok I finally got some pics again.
The beetle's back end with new firewall installed.
From inside the car
My digital dash installed
The boost boxes bolted on the throttle bodies. These still need a lot of work. Intake pipe size 63mm
My modified crank pulley, now with a 60-2 wheel mounted on it for the wasted spark setup.
New 94mm pistons and sleeves... decked to 1.3mm to give me 8:1 compression ratio
Here's some pics of the superlight flywheel I intend using again
My old MSD distributor... I doubt if this one will be used again
[/img]
From inside the car
[/img]
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
