2BugMe
Re: My type 1 turbo project
Post by 2BugMe »
Well done 4Age,
You did well to get her going man...and at least nothing broke or burned hey :wink:
There goes more school fees with the replacement parts...you must be a genius to figure these things out man...
Happy miles...and keep us posted...
:hangloose:
any more news???
4agedub
Been thanked: 13 times
Post by 4agedub »
Hi guys
I have not been on the forum for a while now, things have just been a bit hectic here at work.
Some news.
I started mapping my beetle on tuesday night. Went up to 3500rpm, 0.4bar boost and making 70kw on the wheels so far. Stopped there so I can check all the valve clearances again. Engine temperatures went up to about 68'c and oil pressure stays good.
So I'm very happy. This weekend I will adjust the valves and reset the clearances to 0 again (cromoly pushrods) So next week we'll map her to 6500rpm and 0.8 bar boost. :)
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
Nice, thanks for the update
Quick question, does Gotech sell 60-2 trigger wheels?Or would I have to modify a Bosch Part from a Mercedes Benz or something similar?
4agedub
Post by 4agedub »
We make trigger wheels. The one on my beetle was a once off wheel, but we do keep bigger one's in stock.
4agedub
Post by 4agedub »
A small update.
Got my semi's fitted.
Front's running dunlop semi's 195 and back running bf goodrich drag radials 205
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
The crank angle sensor is now mounted as well.
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
The turbo with air cleaner mounted. Firewall dummy installed, now just need to be painted.
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
The firewall from inside the cabin.
4agedub
Post by 4agedub »
Now this part I'm very proud of... quick release rear window. I modified the read window rubbers to simply slide in and fastened the window with Dzus fastners for quick release.
So to get to the engine bay simply remove the rear window and open the firewall.
