- vader
- Has thanked: 9 times
So Pine do you like the distraction????
thanks for the laugh....
- Has thanked: 235 times
- Been thanked: 234 times
Like it? I LOVED it!!!vader wrote:So Pine do you like the distraction????
Vader, I owe you a few beers next time we meet, thanks
Psssssssssssssssst.... Vader!
Any Scully nudie pics in your stash, perhaps?
Thanks2BugMe wrote:Hey Pine,
Man dude you r doing gr8 work... and all the advice ppl are sharing is making me learn soooo much...![]()
It took me 2 days to read throught this thread and i have been making notes all along...![]()
Firstly your Stearing wheel rocks...man!!!
I had two extra kits that I sold on the Forum a while ago, I found them new old stock in a parts shop in Vereeniging where they have been lying for the better part of the past 25 years on a shelf. There weren't any more, but I'm sure with a bit of searching one should be able to source it somewhere else. How about a CitiGolf setup?Secondly: a few things id like to ask.. bear with me if you dont mind...
Window washer bottle and mechanism: Do you still have extra set for sale or where can i get that
Yes, I can't see why not. Unfortunately I do not have another one. The metal nozzle is from a 1965 Mercedes 230S (fintail), a car that actually had two of them fitted to a VDO rubber 'pump' that you pumped with your foot to pressurise the water in the reservoir, just like a water pistol. If you really want to go to the extreme, the S-class W126 Mercedes has a nozzle with a little electric element to de-ice the nozzle before spraying the water on your windscreenWindow Jet Nozzels: Would they work on a standard late model beetle and do you have one for sale - i like the metal parts
Golf 1 steering column assembly that fits the Beetle steering tube like a gloveGolf Indicator/wiper Unit: Is that golf 2/3 unit and how will that go around a beetle steering colomb??
Wish i could do IRS on my project beetle...ag, mayb some day...
I was just lucky to get the 1302 earlier this year as a donor for some of the goodies
Thanks, I use the thread as a constant motiviation to keep momentum (something one tends to lose easily with this type of project). I am by no means a technical guru, but it is a worthy learning curve, and I'm enjoying every moment of itShot Pine and everybody contributing...amazing thread amongst so many..
....not to mention the occasional seat cover thrown in unexpectedly
- vader
Some progress on the chassis after spending another weekend at IMPI, the IRS chassis is starting to take form - slowly but surely from this
to THIS!!
[/to THIS!!
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
Pine wrote:Have you got good news for me? (In that case shouting is OK)
- buggyfan
- Long Block
Pine wrote:Aaaaaaaaaaaaaah - I like what I see! When can we meet?
im still on dayshift till thursday ,you decide
Well thanks to Jaco (Buggyfan) I got some nice Type 3 brake drums, backing plates, brake shoes and components, so I won't be using this anymore!
I can't get a definite answer from TheSamba, but I need two connecting links (arrowed in the pic below) from a Type 3 - no-one can tell me if those off a Beetle will fit?
ZeroAxe
- Drive Train
Pine I am not sure, because the the brake drums are wider. But then again, I dont have the two next to each other to compare.
VW Enthusiast
strangely enough, both my swingaxle Type 3s have the IRS torsion bar coversThe two IRS torsion bar cover plates, compared to a normal Beetle plate at the bottom
