Re: My type 1 turbo project
Man,I tell you what,that is one sweet sounding Beetle,and it is GO to match the sound!!
Very good job 4age.
4agedub
Been thanked: 13 times
Post by 4agedub »
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
Has thanked: 19 times
Shit thats a pity what happend but as you say there is a silwer edging on the cloud :D
vader
Post by vader »
Did you get it side ways out of any corners.... The grin on your face must have been 360deg!
4agedub
Post by 4agedub »
There was a leak on cylinder nr3. As soon as you get a leak, it'll make a blow tortch effect. There is a hole on the side of my cylinder head.... but at least it's fixable.
The traction with my semis were quite good, only wheelspin in 3rd gear on the table top. I was really surprised with the torque... It took my about two laps to get use to the torque. She scared my big time. :) Awesome topend speed as well
Do you lap your cylinders into the cylinder heads with valve grinding compound? I believe that quite a few Type 4 guys do that to ensure a good seal,as type 4's have a bit of a leak issue when the washers collapse.
4agedub
Post by 4agedub »
I think there's two reasons here...
1. Bad cylindr head. Maybe bubbles in the casing
2. Cylinder depths not the same.
I'll keep that in mind as well.
4agedub
Re: My type 1 turbo project (going historic racing)
Post by 4agedub »
So I've taken out the turbo engine, this will be going into my project split. The change over has started to go race historics.
In november we moved to a new house so all work stopped... till now. :)
Here she is in her new room.
4agedub
Post by 4agedub »
The digital dash was removed. A set of auto meter instruments will now go in to keep an eye on the n/a engine. As soon as the shops open again I'll get a piece of aluminium to refab a new dash.
The tach is just over 3" with memory recall. (So my dad can check that I keep the rpm to a resonable level) :wink:
4agedub
Post by 4agedub »
Oil temp, Oil pressure and volts. What more do you need... Oil temp in 'f to keep to the californian style.
The setrab cooler stays, now with ducting to force all the airflow available through it. The ducting was fabbed from a for sale sign and duck tape. Easy to work with and light.
4agedub
Post by 4agedub »
The number plate is equipped with quick release fastners, so I can drive to the track and take it off in 2 seconds flat.
The 1300 tranny will stay untill my new tranny is finished.
4agedub
Post by 4agedub »
MSD ignition will take care of the spark. MSD billet distributor with manual advance (no electronic advance allowed in historics), 6AL module with 7200rpm limiter and MSD 8mm plug leads. Potent enough for any electric fence :)
The fueling will be taken care of by a set of 44mm Weber IDF carbs. We're assembling the engine on friday. I'll try to take some pics :hangloose:
ZeroAxe
Drive Train
Re: My ex type 1 turbo project (Changing to Historic Racer)
Post by ZeroAxe »
It has bee na while since you updated the thread. All looking good so far(with the change over). So what size n/a engine will go in here?
VW Enthusiast
4agedub
Post by 4agedub »
For now a wild 1776cc type 1.
Counterweight 69mm crank
90.5 mahle pistons and sleeves
Scat c55 camshaft
Type 1 modded heads with bigger valves and huge ports
Standard rockers
Cromoly pushrods
Weber 44mm idf carburetors
Dry sump
Later maybe a 1914cc type 1.
ZeroAxe
Drive Train
Post by ZeroAxe »
So how does the Historic's rule work then? You can put any size of motor with tricketry you want as long was it is N/A?
VW Enthusiast
