My Beetle
- DR WATSON
- Clutch
- What model do you have?: 56,66,69,73,FLEET
- Has thanked: 7 times
- Been thanked: 4 times
Re: My Beetle
Muds if I catch someone knocking on my car, he soon will be knocking on heavens door
Lol
- ADZ
Re: My Beetle
lol yeah when i first saw it i said the same thing there's no door handles it works with a remote pop out and electric windows....lol
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Re: My Beetle
Hello ADZ.
What happens if your battery is flat or even worse if the ciruit fails to those switches? How do you open the doors?
- Drusky
- Has thanked: 77 times
- Been thanked: 15 times
Re: My Beetle
I've never seen one of these before. Moulded? Am I corrrect in understanding that this is a beetle that has been encased in fg using a mould? Are all the bits encased? Why not just make moulded parts instead?
- ADZ
Re: My Beetle
- riaanj
- Has thanked: 6 times
- Been thanked: 41 times
Re: My Beetle
Boet that looks really nice hey, I'm not a big fan of the moulding in of the wings, but your car is beautifull..
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
- Muderick
- Has thanked: 42 times
- Been thanked: 69 times
Re: My Beetle
ADZ I am almost positive that this car is not moulded in one piece like a full on moulded one piece front end for a drag or race beetle. If it was your entire car would be made from fibre glass (perish the thought
What happened here is that the fenders, if they are metal, were either welded onto the body, the seams filled, and then filled with body filler/putty. Same applies to the front fenders against the front apron, as well as at the rear apron. Also looks like the runner boards were joined to the fenders in the same manner. Please make sure nobody stands on them. ...
Having done these kind of custom tom-foolery to beetles about 20 years ago, I know that you will seldomly be locked out, even when the battery is low. The door will open 95% of the time, as if the correct solenoid is used, it only requires a fraction of the power you would normally think it would use to open the door. When the remote is depressed, the solenoid simply releases causing the electrical circuit to be interrupted. Good quality new rubber will always ensure that the door immediately pushes away from the door frame, allowing you to pull on the door handle to open it further...
My mate Ichraam who used to build these gadgets even had a silicone keypad which was adhered to his pop out window, just behind the door post, which could be used to key in a PIN to open the door in the event the remotes battery vrekked or the remote conked out. His volla could also be remotely started from inside his house... provided it was left in neutral. The bug also started with an encrypted credit card, so yes keyless entry and starting way way before the Mercs did it...
Aaahh! the good old days...
Old School or Bust!
- ADZ
Re: My Beetle
pop outs on the rear window that would be cool damn didnt know this until now
well you learn new things everyday i guess but that really cool .........credit card entry hahahahaha
- Bratjie
- What model do you have?: 74
- Facebook: https://www.facebook.com/juan.buter
- Has thanked: 3 times
- Been thanked: 5 times
Re: My Beetle
Tell us a bit about your engine also?
Esté robusto, ser fuerte!!!!
73 Beetle project
73 Beetle project
- Hloni
- Has thanked: 14 times
- Been thanked: 11 times
- ADZ
Re: My Beetle
i also have some kak with the water pipes had ran it underneath the car but its to low so over bumps it damages the piping
- ADZ
Re: My Beetle
the paint work is really nice just that it has a few fine scratches at the right tail light from a dog jumping on it but other than that it nice even better after i polish her up
- Phillip
- What model do you have?: 72 & 56 oval
Re: My Beetle
Nice one I like it. ill leave the motor and put a 36 weber on there. Ull def feel the diff.
