Have you heard the one about the 3 Brazilia ns
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Re: Have you heard the one about the 3 Brazilia ns
Post by buggyfan »
Yes ,saw that aswell when I checked the pics on the pc
Johan Eagle
What model do you have?: 78 Brazilian vw Komb
Post by Johan Eagle »
The body hanging in the shop is a Porche Spyder body with a mdified backend.
What the speed of the fugly is concerned mine done 80km /h full throttle to Humansdorp and 90km/h back (maybe that is why they put up so many windmills for power on the side of the road LOL)
That is with a normal 1600cc and 15inch rims.
Sory guy's it is not an Eagle hanging!!
Greetings
riaanj
Been thanked: 41 times
Post by riaanj »
Johan Eagle wrote:The body hanging in the shop is a Porche Spyder body with a modified backend.
Greetings
Aaah.. that's what got me, the modified back.. ( & no doors)
Thanks Johan
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Cyndi Kritzinger
Facebook: yes
Been thanked: 64 times
Post by Cyndi Kritzinger »
HI GUYS.
JUST GOT BACK LATE LAST NIGHT.
NOTICED SOME OF THE RESPONSES AND JUST WANT TO SHED SOME LIGHT ON THE SUBJECT.
FIRSTLY YES; WE PUT THE 80KPM STICKER ON TO STOP MOTORISTS FLASHING LIGHTS, HOOTING ETC.. AT OUR SLOWER THAN FREEWAY SPEEDS, AND GENERALLY JUST AS A COURTESY TO OTHER ROAD USERS.
SECONDLY. THE BUS COULD PROBABLY DO 100KM'S AT A PUSH, HOWEVER WE HAD MADE A DECISION NOT TO PUSH THE BUS TO IT'S LIMITS DUE TO THE LENGTH OF THE TRIP AS WELL AS THE LOAD IT WAS CARRYING. I KEPT IT AT A STEADY 80KM'S WHERE POSSIBLE AND ON THE ODD OCCASSION FREE-WHEELED DOWN SOME OF THE LONGER, STEEPER HILLS.
THIRD. HERMAN'S ENGINES PERFORMANCE WAS NO BETTER THAN THE EXISTING ENGINE. IT WAS HOWEVER QUIETER WHICH I ATTRIBUTED TO THE EXHAUST.
FOURTH. THE GEARBOX OIL WAS DRAINED AND CHANGED BEFORE THE BEGINNING OF THE TRIP AND THEN CHECKED AT UMTATA. THE OIL WAS CLEAN AND NEEDED NO TOPPING UP.
FIFTH. THE SEALS WORKED PERFECTLY WELL FOR UP TO 60 -70 KM'S AND THEN SOMETHING OBVIOUSLY WENT WRONG. SO FAR CONSCENSES SEEMS TO BE THAT IT IS MOST LIKELY THE SPIGGOT SHAFT OF THE GEARBOX CAUSING THE PROBLEM. ( I WILL BE CONTACTING BUGGER TO SEE IF HE WILL CHECK IT OUT FOR US)
SIXTH. WE RUN NORMAL 15" RIMS AND TYRES SO NO EXTRA STRAIN ON THE ENGINE FROM THAT.
THANKS GUYS FOR YOUR INPUT AND INTEREST. WE APPRECIATE ALL OF IT.
MARK
Hloni
Has thanked: 14 times
Post by Hloni »
retrovan wrote: Not just Fat, but big as well.... :shock: ...245 x 75R x 15
...She looks like :bn: but runs like a F1
I'm not a bus fundi, but I see that you bus seems to ride higher that Cyndi's bus? Her wheels tuck under while yours can't due to size?
How did you get this right, and what happens under load or when hitting a bump/dip in the road, don't the wheels touch/scrape against the body?
3011
Has thanked: 424 times
Been thanked: 542 times
:lol: :lol:
Yes you right,
If you have a look from the side, you will see that I, with much care, cut the back "mud guard" in the same shape as the front, but higher.
This allows the wheel to "full Travel" outside the wheel arch.
Not sure what others think, :roll: , but I love the stance of the bus, and it gives it a bit more of a credibility look from the otherwise bit ugly look of all Brazilia's
Don't worry Squire, there's a Splity just like your Fugly down in Melkbos.
Don't know whether the new owner, Niel, is gonna change it back tho.
hitlers revenge wrote:Don't worry Squire, there's a Splity just like your Fugly down in Melkbos.
Hey !! thanks HR, maybe you can get him to post a pic of his bus, would love to see it.
I see tyres are back to 15's but body still cut.
hitlers revenge wrote:I see tyres are back to 15's but body still cut.
But mine is cut with more fineness......... :lol: :lol:
Thanks HR
:wink:
Koos_JJ_van_vuuren
Post by Koos_JJ_van_vuuren »
The Blue one... was it registered in Pinetown Kwazulu?? hahahahahaha
