- 4agedub
- Has thanked: 4 times
Re: My ex type 1 turbo project (Changing to Historic Racer)
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
- 4agedub
Eina!
- 4agedub
Here's some pics of the racing.
- 4agedub
- dubster
- Been thanked: 3 times
Hey louis...awesome racing on saturday was nice to meet you...i see the bug is having a hard time in the d class....what you gonna do about it?bigger stronger motor or tune the motor down so you can run in e class again?
1974 1300tp type 1
kart kraft 1717cc buggy
- What model do you have?: beetle
- Facebook: vuyo dube
the rims looks so cool no yo! bug
60s look 74 beetle
skype: afronotch
skype: afronotch
- 4agedub
Nice meeting you too Dubster.
We're building a bigger engine with fuel injection! My fuel injection proposal was accepted by the committee, I submitted enough proof that beetle's were built with fuel injection.
For next year we will probably run my 2165cc engine. I've already ordered the new cam as well... Engle fk89
- dubster
Nou gaan hulle k@k!good luck louis...
1974 1300tp type 1
- 4agedub
I've started sorting out the rear fenders. Got a set of fenders from volkspares. I'm planning to mount them with dzus fasteners for quick removal.
Engine and gearbox is out as well for more mods
While stripping the car I've also found the oil leak... darn alternator stand broke off the base!!! Probably also part of the rear end smash damage.
- 4agedub
I've started fitting the fenders.
- 4agedub
- 4agedub
The lh fender fits perfectly, the rh fender needs to go to volkspares for some alterations. It has been cut too short
So far only one dzus fastner keeps the denfer in place, but it looks like it'll hold nicely.
- 4agedub
I've started assembling the big engine again. We need more hp!!!!
The engine is:
EMPI ally casing
78mm crank
94mm pistons and barrels
H-beam cromoly connecting rods
fk89 camshaft
Twin 48ida carbs
CB performance 044 super mag heads.
12.5:1 static compression.
The bottom end is assembled, the next step is to do deck heights and then port the cb heads. Will post pics of the heads when I start.
The engine is:
EMPI ally casing
78mm crank
fk89 camshaft
Twin 48ida carbs
isnt that cam a little big for a race track? Surely its going to kill your low rpm torque.
