BARON
Post by BARON »
Hi 4agedub
Somewhat of the subject ,- is your dad the great rally driver from the early 70s?
thanks,
baron
4agedub
Been thanked: 13 times
Post by 4agedub »
:) I've actually heard this question a couple of times... no he is not.
My dad did race dirt oval track in the eighties and nineties, but not rallying.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
2BugMe
Post by 2BugMe »
Hey there...how is the project coming on??? Have any picture of the type of pipe work you intend to use???
Would love to know what a turbo setup would be like on a stock standard type 1 motor..
4agedub
Post by 4agedub »
I'll probably start woring on her by next week again. Got my sleeves back today, so now I can finish off the engine
Just to tickle you here's Dave Rowley's setup for his buggy:
Boxer Turbos sound cooooool :cool:
4agedub
Post by 4agedub »
Ok I finally got some pics again.
The beetle's back end with new firewall installed.
From inside the car
My digital dash installed
The boost boxes bolted on the throttle bodies. These still need a lot of work. Intake pipe size 63mm :)
My modified crank pulley, now with a 60-2 wheel mounted on it for the wasted spark setup.
New 94mm pistons and sleeves... decked to 1.3mm to give me 8:1 compression ratio
Here's some pics of the superlight flywheel I intend using again
My old MSD distributor... I doubt if this one will be used again
[/img]
Looking good. Plenty $$$$ ? :(
Has thanked: 19 times
Cool man now not to long to go :D :D
I'm interested in that 60-2 wheel, what car did it come of?
Looking really good-Can't wait to see it in action...
4agedub
Post by 4agedub »
Ivan at Volkspares got it made up for me and fitted it to the crank pulley. Now I can go completely distributor less.
4agedub wrote:Ivan at Volkspares got it made up for me and fitted it to the crank pulley. Now I can go completely distributor less.
4agedub
Post by 4agedub »
Distributor less... Coil per cylinder, no more distributor. Like the new gen cars. :)
On the STF, I saw a guy mount a Ford EDIS trigger wheel similar to yours behind a type 4 fan...
Would like to try that when I do my conversion...
So you are making a Deek then :twisted:
