clement
Posts: 51 Joined: Thu Jun 18, 2009 12:26 pm
What model do you have?: 60 Vrod, 62 Crew Cab
Post
by clement » Wed Sep 23, 2009 5:26 pm
Hi Guys
I am currently sorting the suspension on my double cab and would like to upgrade to front discs, is anything like that available in SA or is the only option to get it from overseas?
Been thanked: 1 time
Post
by Chris » Wed Sep 23, 2009 5:28 pm
Hallo Clement.Speak to calooker,I'm sure he can help you out.
Donovan D
Posts: 2231 Joined: Sun Jun 01, 2008 6:27 pm
Has thanked: 148 times
Been thanked: 73 times
Post
by Donovan D » Wed Sep 23, 2009 5:33 pm
Im lookin to do the same on my bus but am clueless, and kits from overseas are rather expensive,
and I do not want to loose the 205pcd, yes yes adapters but the wheels come out then,
Posts: 4054 Joined: Fri Aug 29, 2008 4:16 am
Has thanked: 1 time
Been thanked: 21 times
Post
by Ron&Gill » Wed Sep 23, 2009 6:04 pm
I've just had a set made up by Dave Rowley, they apparently put the wheels out by 15mm.
clement
Post
by clement » Wed Sep 23, 2009 6:19 pm
Ron&Gill wrote: I've just had a set made up by Dave Rowley, they apparently put the wheels out by 15mm.
Sounds good, how much does Dave charge for it if I may ask.
Donovan D
Post
by Donovan D » Wed Sep 23, 2009 6:26 pm
clement wrote: Ron&Gill wrote: I've just had a set made up by Dave Rowley, they apparently put the wheels out by 15mm.
Me too please !!!...and will it work with dropped spindles ??
Posts: 1670 Joined: Tue Aug 26, 2008 7:40 pm
Post
by 1972 » Wed Sep 23, 2009 6:36 pm
Splitz wrote: clement wrote: Ron&Gill wrote: I've just had a set made up by Dave Rowley, they apparently put the wheels out by 15mm.
As long as it is based on the stock spindle setup you will be sorted.
