Can anyone tell me how long the body to pan seal is in length? Volkspares is out of stock and Pro Auto Rubber sells it per meter.
Body to Pan Seal
- Kafer74
- What model do you have?: Beetles
- Has thanked: 37 times
Body to Pan Seal
Hi
Enjoy the Ride
1970 Westie called Ben
- MINCE
- Has thanked: 4 times
Re: Body to Pan Seal
tried to find the length by doing a search but no luck
- Sambabus
- Short Block
- Has thanked: 39 times
- Been thanked: 14 times
Is it just a bitumen type of tape? If so,I can source it for you,probably alot cheaper than Volkspares
- JamesD
- Been thanked: 20 times
No, its a moulded rubber. My guess would be 9 meters.
From fastest to slowest:
'75 SP 1600 with a few mods
- IMPI
- Been thanked: 78 times
Hi I dont use the stock VW type rubber but rather some closed cell foam tape frome your hardware store. I did a rough measurement and think 7m should be enough they come in 5m rolls so 2 should suffice buy 10mm x 40mm or 50mm with the sticky side to the pan.
We removed a pan after 13 years and this foam strip was like new
- Sambabus
- Short Block
There a synthetic rubber used in the roofing industry at a fair price,and it was designed for this app.
