64 Split Crew Bus Restoration
Francois Swart
What model do you have?: 1964
Post by Francois Swart »
I am restoring a 64 Split window crew bus. The chassis is very rusted. I can only use the main frame. I do have access to a 1972 Bay window crew bus with a chassis which is OK. Will it be possible to fit the 64 Splitty body on the bay window chassis. If so are there any major pitfalls. Any help or suggestions will be welcome.
Re: 64 Split Crew Bus Restoration
While it's not impossible to replace the chassis frame on a VW bus, it's not a simple process as the body/chassis are of unitary construction, unlike on a Beetle where the body is bolted to the chassis.
It may also be possible to use some baywindow parts for split bus body repairs, but the work involved in cutting and reshaping is probably not worth it.
You'd be better off contacting Splitbusahollic and buying some of his Klassicfab repair panels. Whatever they cost will be cheaper in the long run than what you propose.
Hi, please post some photos of your '64 bus. Has it been resprayed at all - would be very keen to see some pics of it ? Cheers
Francois Swart
I am still new to the forum. i will try and post some pictures of my beetles & busses.
Has thanked: 19 times
I have actually dismantled a split bus and have a complete Chassis available
But I can also help you fitting some of the repair panels to make your bus sound again
Where in SA are you ?
