But doesn't bother me because its still a Buggy and that's what wanted.
Pics from add
And 2 hours later
After one day
If any body got info on this type buggy I would be really glad.
Thanks for looking
Also thought that. When first started it, it blew of the oil cap from all the blowby. But must say. once I got the carb tuned. it started first kick every time. Too bad it smocked like mad. Thanx for the infoTony Z wrote:good to see the progress.
Your ring gaps... probably what happened was someone installed new 1600 rings onto an oversized piston. I once paid someone how came highly recommended to replace my rings. Couldnt for the life of me figure out why I had so much blowby afterwards. Was told they will run in. When I took the engine apart I found they were std rings on a 1.5mm oversize piston... similar issue to what you found
Thanx manMarshallGTi wrote:
This is not that bad. When it comes to body panels it gets hard.Loopy wrote:Why is that some people can make fabrication look so easy....??
Looking good!
Yup not the best looking but still like it.MELLO YELLOW wrote:Nice work I have the same Kestrell buggy, but I do not like the shape, hence the sale to Cedric so luckily I have another body which I think is a Loletta
I see that yours is a LWB
Done the same kind of frame on my buggy pan
Keep up the good work and post lots of pics
