Conversion
Conversion
I was going thru the specifications of the Remmele Beetle.I noticed that it is based on a 1984 Mexican Beetle.Mexican Beetles are all swingaxle.The Remmele beetle is converted to IRS using Porsche 944 parts .Is it feasible here in ZA to convert a swingaxle Bug to IRS using bits from a Porsche 924/944?You would obviously have to get a different gearbox, but the rest of it?Can it be done?
IF only bloody VWSA gave us IRS...........Sigh
Merlin
Has thanked: 20 times
Been thanked: 39 times
Post by Merlin »
How rich are you?
924s can be picked up cheaply.
I'm sure IMPI can advise you what the possibilities are.
...only because they are DAMN expensive to keep on the road. You won't find an immaculate 924 with a FSH 'cheaply'.
Don't even go 928, either :shock:
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
IRS is not to difficult to do. But finding the parts is the issue. 924 s used bug rear suspension and the only real gain would be the aluminium trailing arms for a 944. The gearbox is a bitch to find and the axles even more But it can be done
