"Understeer is when you hit the wall with the front of the car, and oversteer, the rear. Hp is how fast you hit the wall, and Torque is how far you take the wall with you."
It depends entirely on how you want to mount it your car.
Some elect to fabricate a badge bar, others use a bumper bolt as a base, etc..
They originally came with a long steel bracket with pre-drilled holes to match the holes at the base of the badge. You then bent/cut/drilled the bracket to fit where you wanted to mount it.
Brandenmance wrote:Temptation!! That would look so cool on the front of my camper.
oldschool75 wrote:@merlin, you "blue steel looked" him right into the deal....
