Anybody here know the solex 34 carbs.
Cause i give up. Need somebody to rebuild or tune them for me
any carburettor pros
danthemetalman
- What model do you have?: 76
- Has thanked: 3 times
- Been thanked: 2 times
Re: any carburettor pros
Where in the world are you.
Then we can tell you.
danthemetalman
- Has thanked: 45 times
- Been thanked: 208 times
Too much fuel pressure will overcome the force of the little floats. Especially with the twin 34PDSIT carbs. Then fuel gets forced through, causing over-fueling and eventually fouled spark plugs. For 34PDSIT (which came with your 2L "CJ" engine), float level is best at 14mm.
Most atermarket electric fuel pumps have way too much pressure for this application. In one instance i found that it was violating max allowable pressure by 500%.
Other thing is that the twin 34PDSIT carbs came with 1.2mm needle/seats, (needed by the small floats), and not the more common 1.5mm ones as found in single 34PICT beetle carbs. Sometimes people fit the incorrect ones.
danthemetalman
Thanks for that.
Is there a inline regulator i can purchase from a diferent car that I could fit?
Or suggestions to reduce pressure.
How pressure is needed
- John Alves
- Been thanked: 48 times
You haven't told us what the problems/symptoms are???
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
1968 1500 SP Beetle
John asked:"You haven't told us what the problems/symptoms are???"
Some more info in his other threads:
http://www.aircooledvwsa.co.za/viewtopi ... 23&t=34251
http://www.aircooledvwsa.co.za/viewtopi ... 87&t=34268
danthemetalman
Sorry my bad.
Had a massive over fueling problem but since fixed that part.
Now i need to tune them and cant find much info on tuning the twin port pict 32-34.
And usefull info?
And usefull info?
