Hi
I have started on my project and the previous guy has installed an 1800 Golf engin in the Splitty with 2 radiators at the bottom. I would have initially kept that setup but vehicle was standing for very long time and engin does not start (ring gear stripped) and pipes etc are perished. So I am thinking, instead of spending on the 1800 should I not just buy a aircooled and re-install that. If I am not mistaken, the Fleetline splits came with a 1600.
Two questions:
1. What engin to buy for maximum value add to the bus
2. Where can I buy it
What engin to buy for 1975 Splitty
- Merlin
- Has thanked: 20 times
- Been thanked: 39 times
Re: What engin to buy for 1975 Splitty
Fleetlines run 1600 TPs with heavy duty oil-based air filters. To the best of my knowledge, they were the only T1s to run 1600s.
Despite being Brazilian CKDs, they used South African-assembled motors.
- sean
- Has thanked: 63 times
- Been thanked: 227 times
As Merlin says, 1600 TP motor. It would be a far better idea to throw out the bastardized golf engine.
You will however have to restore all the panels and plates in your engine bay before the aircooled motor can go back in. The golf engine will have cut the engine bay quite badly. Post a pic of the current set up to assess.
Think you will be paying approx. R18 k for a out of hand built up engine from a reputable seller.
But buying a engine of the internet would mean you would have to spent R18k to have it done up.
Maybe looking at the golf motor seams more cost effective.
Try Arno at Andrno in Villiersdorp at 028 840 2087
Got all my aircooled engines from him without issues and couriered them home.
Vdubtech can Help you with a Fully Refurbished Engine
Powdercoated TIn
New Alternator and Carb and Exhaust and a Gtech Ignition System
Outright you are looking at around R50K for such a engine complete bench run here in JHB
Pierre 0826008663
We could possible trade the Golf motor for a few RR`s
Powdercoated TIn
Pierre 0826008663
