Golf 5 gti
lista544
What model do you have?: golf 5 gti 2007
Golf 5 gti
Post by lista544 »
Car smokes iv'e change the oil 5-30 to 5-40 bt still smokes wen i give acelaration bt not all the times mileg 193 plz helpImage
Sent from my ANE-LX1 using Tapatalk
Re: Golf 5 gti
Buy a Beetle
lista544
Re: Golf 5 gti
Post by lista544 »
Done.. bought 3 of them
Vintage man
Has thanked: 51 times
Been thanked: 7 times
Re: Golf 5 gti
Post by Vintage man »
Are you using oil.
If you let it idle for a couple of minutes and then rev does it smoke,If yes valve stem seals.
Could be oil rings that have collapsed or worn.
Can you do a compression test.If compression is low then put a small amount of oil in the cylinders and repeat the compression test.If the compression picks up after you put oil in the cylinders then its rings.That will give you a guide as it does not necessary mean the oil rings but will indicate that rings are worn.
If it was a beetle then its ok as its old enough to smoke.
lista544
Re: Golf 5 gti
Post by lista544 »
Vintage tnx boet
Re: Golf 5 gti
quite likely the turbo
engine is still newish
lista544
Re: Golf 5 gti
Post by lista544 »
The car i took in bra i"ll let u knw wat happnd tnx alot again bra
Eugene
Has thanked: 59 times
Been thanked: 65 times
Re: Golf 5 gti
Post by Eugene »
lista544 wrote: Thu Apr 02, 2020 10:51 am Car smokes iv'e change the oil 5-30 to 5-40 bt still smokes wen i give acelaration bt not all the times mileg 193 plz help[IMG]https://uploads.tapatalk-
Please god....not another one :evil:
lista544
Re: Golf 5 gti
Post by lista544 »
Eugen wat u mean?
Re: Golf 5 gti
lista544 wrote: Fri Apr 03, 2020 2:48 pm Eugen wat u mean?
he's just a miserable old fart ;-)
:drunks:
lista544
Re: Golf 5 gti
Post by lista544 »
Tony u were right brother (tarbo seal..) Prblm.. they can fix wat i have or buy a new one.. So again tnx alot buddy.
Re: Golf 5 gti
fix it, get OEM parts
buying new will likely get you a cheap part and it'll only blow again in a few thou km
lista544
Re: Golf 5 gti
Post by lista544 »
Salute
