Wasserboxer engines
Wasserboxer engines
What's the deal with these?
Are they suitable for use in a mild performance application?
I believe that they suffer from head stud corrosion issues, but if you look at the 2,1's standard power output (82kw and 174 nm) it could be some fun if you tweak it further...
Comments?
Comments?
I have been for a ride in a bug in the UK owned by a guy who works for Porsche. Waterboxer turbo. At that stage it only had 180hp on the tyres... The last time I heard about that car, his tyres slipped off the dyno at 472hp and he was running 9.xx sec 1/4 miles and using it as a street car!!!!!
But dont forget his engine management system cost 6000 pounds
I am currently reconing my moms 2.1 that I originally did in 1993 and all that was the problem was the haed rubber gasket perished and the bus did more than 250 000 km pistons still useable bearings was still fair and the block will need linr boring from rubbing on the centre of the cace from old age and was treated with FUTRON oil for it s life span
The only draw back of the 2.1 are their conrods that must be properly crack tested shot peened and the stretch bolts removed
In a bug these motors are 100% better than a Type 4-- power and reliability
but then its not aircooled any more choices choices choices
- Has thanked: 45 times
- Been thanked: 208 times
Also heard about the conrod problem with wasserboxers.There was a place in Kemptonpark that specialised in wasserboxers,went there many years ago (to exchange a 82mm Oettinger crank i had for a 76.4mm Oettinger crank).Spoke to the main mechanic.He said from about 120000 many new wasserboxers snapped their conrods for no apparent reason.
When they opened these,the bearing surfaces were still excellent,just the conrod had snapped and ruined the case.He said they threw away all used conrods,irrespective of condition and replaced them with new ones.(Then wasserboxers were still in production,so spares availability was different.) Thought it was the high compression of the 2,1 But a neighbours 1.9 (low compression ratio ) did the same.Plenty of used spares available from these in newspapers.
The place you revering to is Volks engin change one of my good friends used to work there Marius who stays down in South port now and that is where I learned alot of the WBX`s
The 2.1 had stretch bolts and 1.9 not from a lot of milage the stretch bolts would sometimes stretch and the bearing would turn and snap the rod
And as Dawie has said many a times a 2.1 would just snap the rod due to the diverent Harmonics in the 2.1 than a 1.9 when I build the 2.1 I try and use 1.9 rods they have a lot less stress on them than 2.1
But I just orderd a set of Uni tech Scat rods for $139 and that is cheap insurance
In a beetle one has not got all this hassels with w WBX the motor is not working half as hard as in a Bus full of passengers and the trailer behind
I love the WBX motors and are buZy with a 2.1 Turbo project as well for a friend
Thanks Bugger for that info,always wondered what caused the rod failure.Never had a wasserboxer,has an Oettinger wasserboxer crank in my beetle.When i was there (Long ago) they had at least 50 Oettinger cranks that came out of engines,both 82mm and 76.4mm stroke.They are counterbalanced and of a very hard material,could be chrome-moly?
- Merlin
- Has thanked: 20 times
- Been thanked: 39 times
Bugger wrote:The 2.1 had stretch bolts and 1.9 not from a lot of milage the stretch bolts would sometimes stretch
