king pins-link pins
- Skymac
- What model do you have?: Bay window
king pins-link pins
where is the best place in pretoria or jhb to have this done?
Once a fanatic, always a fanatic- Sambabus
- Short Block
- Has thanked: 39 times
- Been thanked: 14 times
Re: king pins-link pins
Prestech engineering say thet could remanufacture out of stainless steel no problem,they just need the original i would imagine....thier based in Boksburg,
- Has thanked: 235 times
- Been thanked: 234 times
Werner Alke from the Jacaranda Beetle Club - he did mine on HW2, and you have seen it.
You get a LOT of credit if you bring him your front beam already clean and disassembled
(012) 654 8272
- zubz
- What model do you have?: 62 LHD Rag, 69 Auto
Werner was supposed to have made me an A Frame, somehow he lost interest as he is too busy but damn this guy is good...I am going to call him to see if he would make it....Pine wrote:Werner Alke from the Jacaranda Beetle Club - he did mine on HW2, and you have seen it.
(012) 654 8272
If you look at the pic below, the king pin is the shaft that runs vertically, and on which the stub axles steer (ie turn), the link pins are the horisontal axles (two per side, removed in the pic) on which your suspension travels up and down:zubz wrote:btw guys, what is king pins/link pins?
- zubz
Dankie...Pine wrote:If you look at the pic below, the king pin is the shaft that runs vertically, and on which the stub axles steer (ie turn), the link pins are the horisontal axles (two per side, removed in the pic) on which your suspension travels up and down:zubz wrote:btw guys, what is king pins/link pins?
- Has thanked: 45 times
- Been thanked: 208 times
Thanks Pine for the pictures. Those look like split kombi type,with needle bearings for the linkpins.
Beetle types do not have needle bearings at the linkpins.
Remember, it is VERY important to grease the front suspension at least every 5000 km. Every oil change service should include greasing the front suspension, as was recommended by VW.
Thanks Dawie, it was just a generic pic I got from TheSamba. Needle bearings on the link pins sounds like a good idea, wonder why they discontinued it?
- Been thanked: 98 times
If anyone needs a good quality Brasil set for beetle, I got R500.
Rui 082 830 6493
Rui 082 830 6493
