Progress restoration '64 Bug
riaanj
Been thanked: 41 times
Re: Progress restoration '64 Bug
Post by riaanj »
Dolf Jonker wrote:Its a special process to treat bare metal parts for rust protection, the same as done by the motor manufacturers.
Sweet, thanx man, I learned something now, I'll keep that in mind when I do a resto someday.. :hangloose:
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Bushpig
Post by Bushpig »
Would you get the same protection from powder coating. I wanted to do the fenders and lids sand blasted then powder-coated. Your ideas :zhelp:
MINCE
Post by MINCE »
SOrry dude, but where are you based?
Has thanked: 425 times
Been thanked: 543 times
Bushpig wrote:Would you get the same protection from powder coating. I wanted to do the fenders and lids sand blasted then powder-coated. Your ideas :zhelp:
Do Not Powder coat.......
The right way would be to VERY Carefully, sand blast the parts inside and out.
This must be done by someone that has done body parts before, as if they use to high a pressure, they will warp the panels, and destroy the project.....
ALSO do not use PAINT REMOVER as it will stay dormant on the panels, and attach the new paint every time there is moisture in the air... Car with bubbles, that is Paint Remover...
Then you send them to a OEM car parts manufacturer in your area, that does E - COAT,
For an explanation go to my thread http://www.aircooledvwsa.co.za/viewtopi ... 1&start=30 , to long to elaborate here.
Then you do the body work and spray painting.
If you not going to use body filler, and use lead, then you can do that before E-COAT
Do not powder coat, as this will not give you full protection against rust, and will develop problems later for tough ups.
OMO
Bushpig
Post by Bushpig »
Herman,
Thanks for that I will check out the thread. Any idea what 4 fenders & both lids will cost. I wouldn't attempt the blasting on the rest of the body because of warpage unless I come across someone who has done it with a good blaster. What do they use overseas when you watch shows on TV they send it in for blasting on american cars which have large pannels etc.
MINCE
Post by MINCE »
dont they use soda blasting instead of sand?
Bushpig wrote:Herman,
The big guys in USA use soda blasting, as well as chemical dip bath systems, as well as low pressure blasting.
But you need to cover the clean surface within minutes, else it gets covered in rust.
MINCE wrote:dont they use soda blasting instead of sand?
Soda blasting is becoming more popular here, but expensive due to dust, and single use of media.
Sand is illegal due to silicoses.
They namely use Platinum Slag, in different sizes.
Bushpig
Post by Bushpig »
Are there any soda blasting guys in the w/Cape.
splitbusahollic
Facebook: vintage kombi
Has thanked: 87 times
Post by splitbusahollic »
Hey ! Guys..this is actually Dolf's thread that you are hi jacking ! :lol:
make your own sandblasting/powder coating thread to discuss the issues.
vintage kombi.co.za (Website)
vintage kombi on Facebook
Dolf Jonker
What model do you have?: 1967
Post by Dolf Jonker »
:D
Dolfino
Dolf Jonker
:D :D :D
Dolfino
MINCE
Post by MINCE »
Where are you based?
MINCE wrote:Where are you based?
Dolf is in PE.
MINCE
Post by MINCE »
Thanks Herman.
Was wondering if it was gonna go to "third time lucky"
MINCE wrote:Thanks Herman.
Sorry I spoiled your hat trick....... :lol: :lol: :lol:
