My 1971 Deluxe
- AlanH
- Has thanked: 130 times
- Been thanked: 88 times
Re: My 1971 Deluxe
My Westy, a '70 model has a brake booster but I can see it's been fitted by someone else. The reservoir also sits behind the drivers seat on the separation wall. Maybe that is the clue?
Wanted parts:
Left sunvisor
Sink faucet
Left sunvisor
Sink faucet
brianj
- Single Port
- Has thanked: 13 times
Re: My 1971 Deluxe
My 71 westy also has booster and reservoir behind driver seatAlanH wrote:My Westy, a '70 model has a brake booster but I can see it's been fitted by someone else. The reservoir also sits behind the drivers seat on the separation wall. Maybe that is the clue?
Sent from my SM-G973F using Tapatalk
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
Re: My 1971 Deluxe
AFAIK, boosters were standard on microbuses and deluxes from 1971 model year; optional on kombis, panelvans and pick-ups.sean wrote: Thu Oct 31, 2019 6:03 amIt’s brakes are surprisingly good. It’s a 1971 model, which I know as standard to have disk brakes upfront, but no booster. This bus does have a booster which is odd. It doesn’t appear to be fitted later either. All seems perfectly original down to every hose fitting, brake balancer etc, but it’s not the same as a usual late model either, it is something unique. I wonder if a booster wasn’t an optional extra back then?acpaterson wrote: Wed Oct 30, 2019 9:37 pm Yoh! 160 in a Kombi.. You go bud..
Must be rather scary. Hope it's got uprated anchors all round.
Al
My microbus-based 1971 high-roof camper has factory booster, while my 1971 double cab and single cab have no booster.
- sean
- Has thanked: 63 times
- Been thanked: 228 times
Re: My 1971 Deluxe
This is strange. I have another 1971 Deluxe, 1971 microbus and a 1972 microbus and all 3 have disk brakes with no booster.fig wrote: Tue Nov 05, 2019 12:35 pmAFAIK, boosters were standard on microbuses and deluxes from 1971 model year; optional on kombis, panelvans and pick-ups.sean wrote: Thu Oct 31, 2019 6:03 amIt’s brakes are surprisingly good. It’s a 1971 model, which I know as standard to have disk brakes upfront, but no booster. This bus does have a booster which is odd. It doesn’t appear to be fitted later either. All seems perfectly original down to every hose fitting, brake balancer etc, but it’s not the same as a usual late model either, it is something unique. I wonder if a booster wasn’t an optional extra back then?acpaterson wrote: Wed Oct 30, 2019 9:37 pm Yoh! 160 in a Kombi.. You go bud..
Al
- fig
- Bus Driver
Re: My 1971 Deluxe
I guess that means boosters were optional on 1971 and maybe later buses.sean wrote: Tue Nov 05, 2019 1:39 pmThis is strange. I have another 1971 Deluxe, 1971 microbus and a 1972 microbus and all 3 have disk brakes with no booster.fig wrote: Tue Nov 05, 2019 12:35 pmAFAIK, boosters were standard on microbuses and deluxes from 1971 model year; optional on kombis, panelvans and pick-ups.sean wrote: Thu Oct 31, 2019 6:03 am
While my boosted 1971 microbus has very sharp brakes, the lack of a booster on my 1971 single cab and double cab is not missed. Brakes are still very sharp, but need a bit more leg to get the same braking effort.
- slak
- Has thanked: 7 times
- Been thanked: 32 times
Re: My 1971 Deluxe
Could be that they upgraded the brakes when they did the engine conversion , if
you do a conversion with much more power than the original engine it would make sense to
upgrade the braking system as well
U Only Live Once Right !!!
brianj
- Single Port
Re: My 1971 Deluxe
Could be, mine was a v6 upgrade at one point as well. Now stock!slak wrote: Wed Nov 06, 2019 10:22 am Could be that they upgraded the brakes when they did the engine conversion , if
