My 1971 Deluxe
AlanH
Has thanked: 130 times
Been thanked: 87 times
Germany
Re: My 1971 Deluxe
Post by AlanH »
My Westy, a '70 model has a brake booster but I can see it's been fitted by someone else. The reservoir also sits behind the drivers seat on the separation wall. Maybe that is the clue?
Wanted parts:
Left sunvisor
Sink faucet
brianj
Re: My 1971 Deluxe
Post by brianj »
AlanH wrote:My Westy, a '70 model has a brake booster but I can see it's been fitted by someone else. The reservoir also sits behind the drivers seat on the separation wall. Maybe that is the clue?
My 71 westy also has booster and reservoir behind driver seat
Sent from my SM-G973F using Tapatalk
Re: My 1971 Deluxe
sean wrote: Thu Oct 31, 2019 6:03 am
acpaterson wrote: Wed Oct 30, 2019 9:37 pm Yoh! 160 in a Kombi.. You go bud..
Must be rather scary. Hope it's got uprated anchors all round.
Al
It’s brakes are surprisingly good. It’s a 1971 model, which I know as standard to have disk brakes upfront, but no booster. This bus does have a booster which is odd. It doesn’t appear to be fitted later either. All seems perfectly original down to every hose fitting, brake balancer etc, but it’s not the same as a usual late model either, it is something unique. I wonder if a booster wasn’t an optional extra back then?
AFAIK, boosters were standard on microbuses and deluxes from 1971 model year; optional on kombis, panelvans and pick-ups.
My microbus-based 1971 high-roof camper has factory booster, while my 1971 double cab and single cab have no booster.
sean
Has thanked: 63 times
Been thanked: 227 times
Re: My 1971 Deluxe
Post by sean »
fig wrote: Tue Nov 05, 2019 12:35 pm
Al
This is strange. I have another 1971 Deluxe, 1971 microbus and a 1972 microbus and all 3 have disk brakes with no booster.
Re: My 1971 Deluxe
sean wrote: Tue Nov 05, 2019 1:39 pm
I guess that means boosters were optional on 1971 and maybe later buses.
While my boosted 1971 microbus has very sharp brakes, the lack of a booster on my 1971 single cab and double cab is not missed. Brakes are still very sharp, but need a bit more leg to get the same braking effort.
slak
Has thanked: 7 times
Been thanked: 32 times
Re: My 1971 Deluxe
Post by slak »
Could be that they upgraded the brakes when they did the engine conversion , if
you do a conversion with much more power than the original engine it would make sense to
upgrade the braking system as well
U Only Live Once Right !!!
brianj
Re: My 1971 Deluxe
Post by brianj »
slak wrote: Wed Nov 06, 2019 10:22 am Could be that they upgraded the brakes when they did the engine conversion , if
Could be, mine was a v6 upgrade at one point as well. Now stock!
Nixon75
What model do you have?: 74 s/c
Has thanked: 2 times
Re: My 1971 Deluxe
Post by Nixon75 »
That was my friend Christiaan’s bus!!
Awesome condition!
Congrats
Nico
